Jimmy_jazzy
Jul 14, 2021Aspirant
R6120 - Router Is Slow
Hi there guys, After having a frustrating call with a "Tech Expert" wanting to charge me 200 bucks per year for support, I've scooped down to this low (the forums). I am having very slow speeds wi...
Jul 14, 2021Guru - Experienced User
You're right. It is the router.
Reason why is the R6120 isn't gigabit bit. Its only has 10/100mbps connections.
so you're going to max out at that 90-95mbps max.
for faster speeds, you'd need to upgrade to a gigabit router.
Jimmy_jazzy
And also, it says on the packaging the router can handle up to 1200 MBPS? So, it should be able to handle 250 Mbps.
