Izkiz's avatar
Izkiz
Tutor
Aug 16, 2020
R6700 bricked after firmware version 1.2.0.72
Hello...
I update my router R6700v2 to the new firmware versión 1.2.0.72 and it crash my router.
Is bricked and i can't acces to my router.
I try everything on the internet, TFTP, and others solutions and nothing happends. Still bricked.
I can't ping my router, i try it and nothing.
Any help? or i need to get new router?
  • What tftp method did you use? Did you download the program tftp2.exe to do it? If you tried a different way I suggest you use that tftp2.exe program to do it. Try pressing the reset button for a second or two and run the tftp right after you press it.
    • Izkiz's avatar
      Izkiz
      Tutor
      i only can unlock 2 type of leds
      1- when the router is off, i press the reset button for 30 seconds and i turn on the router... the power led start at color amber /orange and the port of my computer white, then all ports leds off and power led star blinking in white.
      2- when i restart normally my router, the power led in orange / amber and my pc port in white.
      • michaelkenward's avatar
        michaelkenward
        Sorry, it still isnlt clear to me.
        Let's keep this really simple.
        After you have turned the thing on and it has finished the startup cycle, what does the power LED look like? That's the one on the top on the left.
        What colour is it? White or amber?
        Is it solid or blinking?
        The rest don't matter at this stage.
