Num1wop's avatar
Num1wop
R6700 Not able to cast to device (Xbox One) from my windows 10 PC
Just bought the r6700 and can not cast to my xbox one anymore. Im sure its a streaming function in the router but I cannot find it. I tried with QoS enabled and Disabled, but neither worked.  I would like to play my movies from my windows 10 PC to my xbox one like I use to.
  • Thank you for the information. I really needed that clarification. I followed the link and instead of adding the xbox, I deleted it and just re-added it. And they started communicating again.
    • Num1wop's avatar
      Num1wop
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        That's great! Thank you for providing that feedback.
