NetGridlock's avatar
NetGridlock
R6700 Router Randomly Resets
I have an older nighthawk 6700, 4 years old or so.  It started to randomly reset itself.  After a few days this resetting/rebooting happened more and more.  So, figuring that it might be a power supply/board issue I decided to get another router.  I bought the R6700V3 to replace it.  Guess what?  It randomly reboots/resets as well.  I have them both plugged in right now and they both randomly reset, not as often as was the case earlier with the older router.  So, what could it be?  Is it that the router keeps updating or maybe a bug?  Can something the cable modem is doing cause this (only the new router is on the modem).  I see there were issues in the past with this but it has been a long time since anyone complained so I figured the original issue was resolved.  I need some ideas!  BTW, when the new router was first started it did a firmware update.  lil' help!
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Circle, Traffic Meter.
    • NetGridlock's avatar
      NetGridlock
      got home, booted up laptop (wireed)
      started with phone (wireless) was connected fine but wired had no internet.
      Connected!
      15 seconds later a reboot.
      Back Alive...
      The R6700V3 Information:
      Hardware Version R6700v3
      Firmware Version V1.0.4.122_10.0.95
      GUI Language Version V1.0.4.122_2.1.38.1
      Wireless 2.4 Auto(8)
      Wireless 5.0 Channel 149 + 153(P) + 157 + 161
      Guest networks are off
      Claims this is the latest firmware version
      Another unexpected re-boot!
      Seems to be doing this more frequently tonight!
      Cable Modem:
      Technicolor
      Model: TC4310
      Made in China
      Old R6700 Router Information:
      It says it is a R6700V3
      New firmware is found. Do you want to update the firmware?
      Current GUI Language Version: 1.0.4.78_2.1.38.1
      New GUI Language Version: 1.0.4.122_2.1.38.1
      Current Firmware Version 1.0.4.78
      New Firmware Version        1.0.4.122_10.0.95
      I selected not to do the update at this time.
      It says I was successful Installing it, yah right!
      OOPSIES!  Another random Reboot!
      Logged back into old router:
      Firmware Version V1.0.4.78_10.0.55
      GUI Language Version V1.0.4.78_2.1.38.1
      Wireless 2.4 Auto(3)
      Wireless 5.0 149 + 153(P) + 157 + 161
      So, make a guess... The wireless doesn't seem to be an issue even though the channels are different.  The issue is that the whole router resets itself.
