Kardano
Oct 05, 2022Luminary
R6800 MAC adress
Hello,
i hav one problem with my R6800 router. Router is changing LAN MAC adress after every reboot. If i use button "reboot" on router information, after reboot router has new LAN MAC adress.
I tested this thing witn multiple FW over 2 years. no 2 MAC adress was the same.
FW is 1.2.0.92_1.0.1 which is newest.....)
Wifi is disabled.
I tried factory default multiple times, no effect, different FW, no effect..... ..except this one problerm, router is OK. But thi one is problem for Layer2 isolation lists of other AP's in LAN and changing LAN parameters for PC in lan (like if LAN is public/works)
Can someone help me with this problerm if it is possible to help?
Thanks.
Is it running in AP mode?
if so, you should be able to set it with a static ip address on whatever is handling dhcp
