Riley78's avatar
Riley78
Guide
Mar 17, 2022
R6900 speed
What is the max wired download speed will this support? (this is not the version 2 or 6900P)
  • Thanks for the reply.
    I am thinking of moving to a higher speed tier and wondered if a new router would be needed. The link to the R7000 showed a
    speed test result of 950 Mbps which exceeds my needs.
