justin_esta's avatar
Apr 21, 2018
R6900P. Nighthawk AC1900 Smart WiFi MuMimo
Help needed,
I woke up to find out that my fully functioning wireless router has stopped working. The power light remains amber and no other color. It includes two other white LED buttons on Guest WiFi and WiFi On/Off. The network cannot be seen in the list of WiFi networks detectable by any device. I’ve tried to reset the router multiple times, only to have the same 3 LED buttons the same color. I also tried to power cycle both my modem and router, but still no luck. The power adapter I use is the one provided by Netgear. I do not know what else to do to make it work.
  • michaelkenward's avatar
    michaelkenward
    Your router may have been set up to update the firmware automatically. The light you see is a sign of a broken firmware update.
    If your device is still under warranty, I'd start the RMA process.
    The most often recommended way of trying to fix this yourself is described here:
    How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
    That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
    • Control Panel
    • Programs and Features
    • Turn Windows features on or off
    • TFTP client - enable
    That's probably easier than retrieving software from a website.
    This process is not for the faint hearted. Hence the warranty option.
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi justin_esta,
      Have you tried the suggestion of michaelkenward?
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • justin_esta's avatar
        justin_esta
        Tutor
        I was having troubles trying to hard reset my router. When I followed the instructions on rresetting the router, the device did not have a green LED, but instead continued to have the same LED's as explained before. That was the last step needed to upgrade the firmware.
