Jellikit's avatar
Dec 14, 2022
R6900v2 access point or bridge mode for Sonos
I have been battling this issue now for almost a year. I have 2 routers. The primary router is where the internet comes into my house. From there, I have an Ethernet cable that runs approximately 125 feet into my garage and connects to another router (R6900v2). I have problems with my Sonos speakers dropping connection in my garage. In my opinion they are trying to grab the signal from the primary router in the house. I have contacted Sonos, my ISP, and Netgear. No one seems to help. Sonos says put the garage router in Bridge mode. I have tried, but am not tech savvy enough to trouble shoot. When I’m bridge mode, I can not access internet. The last time I asked the Netgear community, I was told to run in access point mode. This does not work either. My speakers play for about 20-30 minutes and then drop. My ISP is no help at all. Can someone please help?!?!?
  • leave the primary router managing it. Sonos will struggle with double nats.
    So having the primary in router mode and the 2nd one in access point mode leaves the primary managing it. It should help with the sonos but you still might need to change some settings in the sonos or set them with static ip address. Their forums will know more about streamlining their setup with router/access point systems.
  • plemans's avatar
    When you say AP mode doesn't work, what actually happens?
    Are you using multiple sonos devices? they're notorious with issues with mesh systems if you search on their forums.
    • Jellikit's avatar
      Jellikit
      Guide
      I have a Sonos system in my house that is connected to the primary router.  Then, I have a system in my garage that is connected to the secondary router (routers are connected to each other via cat 6 ethernet cable).  When the garage router is in access point mode, the Sonos system in garage will work anywhere from 5 to 30 minutes, then it loses connection.  I am looking for a solution as I have a working area and guest area in garage.  Is this doable using existing set up?  Should I be using different hardware in garage like an extender, etc?  I was under the impression that I could utilize the secondary router as either a bridge or access point to run devices in garage.  So in short, to answer your question, the system works sporadically.  Thanks for any help/advice you can offer.
      • plemans's avatar
        The AP mode should be the answer. Do any other devices have issues?
        if not, i'd post on the sonos forums to see what they users on there would recommend. I've seen issues with running multiple AP's and sonos but not sure of the proper answer
