Kholley
Oct 10, 2021Aspirant
R6900v2 power button blinking
The links I was sent from netgear are no help. I’m not sure how to fix the issue. I’m not able to check the ISP connection and DNS settings, upload firmware to a NETGEAR router using Windows TFTP, or troubleshoot
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
