mediaman09
Jul 03, 2014Aspirant
R7000 - Can I turn off the 5G band?
I own the R7000, but currently do not have any 5G(802.1ac) devices so I assume there is currently no advantage for this band for me at this moment. Correct? Is there a way to runs off the 5G band o...
- Jul 03, 2014Ahh found it under Advanced Settings. Was looking under the Advanced tab. Minor item they should address - poor UI to have two different sections both called Advanced.
jmizoguchi
Jul 07, 2014Virtuoso
And think about if your internet is nothing faster than 150Mbps would make no benefits unless you are looking to some LAN to LAN sharing over range is less
