sordini
Oct 28, 2015Aspirant
R7000 - SSID not listed on some devices
I've recently bought an R7000 router and with by far the majority of the devices we have it works brillliantly. However, on one device (a Netgear WN1000RP range extender) the network SSID given out ...
- Oct 30, 2015
So, as mentioned above, a firmware update solved the issue with the WN1000RP. With the netbook, the issue was solved by manually selecting a channel on the R7000 (rather than leaving it at "auto"). We tried this when we realised that the linux driver we're using for the BCM4313 adapter doesn't work on channels 12 or 13.
The curious thing is that prior to setting the channel on the R7000 (and despite the fact the broadcast channel on the WN1000RP is neither 12 nor 13 - it's fixed on 11) the SSIDs of neither the R7000 nor the WN1000RP were listed on the netbook - but after setting the channel both were. We're happy we've solved the problem but nevertheless intrigued as to why this might the case - so if anyone reads this and is able to shed any light on that we'd be really interested.
sordini
Oct 29, 2015Aspirant
Thanks. Looks like it might be to do with firmware (on the devices). We updated the firmware on the WN1000RP and that solved the problem for that device. Looking into a kernel upgrade for the netbook but it's running fine off ethernet for now so we may just leave it that way.
sordini
Oct 30, 2015Aspirant
