Snowmatt
Jul 16, 2015Tutor
R7000 -cant get to work with iptv
Hi, I am having problems getting my r7000 working with plusnets iptv.. Recently signed up for it and they sent me their crappy router which supplies their iptv perfectly but i cannot figure out how t...
- Aug 02, 2015
bill1228 wrote:
Cannot speak to DD-WRT and IPTV but the latest XVortex firmware supports IPTV and is reported to work. Of course there is the question of will this work with your supplier?
Link to that info:
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/page-11#post-263689
Link to the firmware info:
Runs very well on my r7000.
--billAnd we have a fix!!!! Flashed the CFW, quick reboot of the router and a bit of higgery jiggery - working YouView with IPTV enabled.
Here is a note in case others stumble accross this forums and fall into the same hurdle. These are the settings you need once you have flashed the CFW:
You must configure 'Enable VPN + DHCP Connection' to 'No' under the WAN option.
Settings used were:
- Have router on the latest firmware: 3.0.0.4.374.130
- Use the following settings in LAN > IPTV:
- 'Select ISP Profile' = None
- 'Choose IPTV STB Port' = None
- 'Use DHCP routes' = Microsoft
- 'Enable multicast routing (IGMP Proxy) = Enable
- 'Enable efficient multicast forwarding (IGMP Snooping) = Enable
- 'UDB Proxy (Udpxy) = 0
I hope this proves use for others in future and thanks for your assistance all.
Spoiler:smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy:
taylord01
Jan 18, 2016Guide
Just hope others find this post before considering flashing to a different firmware!!
Now my next challenge on the 'R7000 to-do list'....why on earth are my port-forwards not working? Must be something obvious hidden away somewhere! Will pick up another thread for that one ;-)
