Snowmatt
Jul 16, 2015Tutor
R7000 -cant get to work with iptv
Hi, I am having problems getting my r7000 working with plusnets iptv.. Recently signed up for it and they sent me their crappy router which supplies their iptv perfectly but i cannot figure out how t...
- Aug 02, 2015
bill1228 wrote:
Cannot speak to DD-WRT and IPTV but the latest XVortex firmware supports IPTV and is reported to work. Of course there is the question of will this work with your supplier?
Link to that info:
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/page-11#post-263689
Link to the firmware info:
Runs very well on my r7000.
--billAnd we have a fix!!!! Flashed the CFW, quick reboot of the router and a bit of higgery jiggery - working YouView with IPTV enabled.
Here is a note in case others stumble accross this forums and fall into the same hurdle. These are the settings you need once you have flashed the CFW:
You must configure 'Enable VPN + DHCP Connection' to 'No' under the WAN option.
Settings used were:
- Have router on the latest firmware: 3.0.0.4.374.130
- Use the following settings in LAN > IPTV:
- 'Select ISP Profile' = None
- 'Choose IPTV STB Port' = None
- 'Use DHCP routes' = Microsoft
- 'Enable multicast routing (IGMP Proxy) = Enable
- 'Enable efficient multicast forwarding (IGMP Snooping) = Enable
- 'UDB Proxy (Udpxy) = 0
I hope this proves use for others in future and thanks for your assistance all.
Spoiler:smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy: :smileyhappy:
ASHD3
Aug 01, 2015Tutor
Hey SnowMatt,
Just a quick enquiry, did you manage to get this issue sorted with the R7000 Router? I am in the exact same dilemma and Netgear appear to do there utmost best to avoid you at all costs - if it's beyond that 90 days (without linking you to the American Directory to pay a bomb). Just wondering how your luck panned out?
Thanks,
A
TheEther
Aug 01, 2015Guru
Most IPTV providers use IP Multicast but most firmware for consumer routers have little to no support for IP Multicast. The R7000, however, has an option to enable IGMP Proxy under Advanced > Setup > WAN. Uncheck the Disable IGMP Proxying box to enable it. See if this fixes your IPTV problems.
If it doesn't work, then you will need connect your TV settop boxes directly to the ISP's router. You can either use your R7000 as a router behind the ISP router, or use it as an AP. There are pro and cons for each setup. You can look at the FAQs on http://dslreports.com for various setup configurations. The FAQ for Verizon FIOS is very detailed. Not all of the options listed may necessarily apply to Plusnet.
- ASHD3Aug 02, 2015Tutor
Thanks for your contributions.
I have been through that process as you mention Ether originally, following all the guides available and from the Netgear website (as the OP mentioned) looking at VLAN tags here. These sadly did not produce any result and also leaded in struggling to find the VLAN tags for the ISP.
I want to avoid having multiple pieces of equipment plugged in more specifically so with the router not being VDSL enabled. After looking at Bill's post from earlier on, I will give it ago flashing this CF and see how the results entail. I just wanted to know if Snowmatt had any luck doing so with being on the same VISP. However I can see Bill added a note to say this is running smoothly on his device.
Again, highly appreciated for the help.
- TheEtherAug 02, 2015Guru
ASHD3 wrote:Thanks for your contributions.
Can you confirm that you tried enabling IGMP Proxy on stock firmware, and it didn't work?
Hey Ether,
Yes that's correct.
- SnowmattAug 03, 2015Tutor
Hi, no I didnt get anywhere with this. I am still trying however so will post back here if i do figure it out. I did try enabling the IGMP proxy, but that didnt change anything. Apparently using the VLAN options will work, but whenever I enable this, the router wont sync to the internet.
I was loathe to install another firmware but i may do this if it works.
I will try the XVortex with the settings suggested, thanks!!
