cabeaulac's avatar
cabeaulac
R7000 1.0.9.x reboot cycle
My R7000 was bricked. After finally figuring out how to configure Terminal on MacOS to let me Ctrl-C the boot process so I could turn tftpd on, I can now reflash the firmware. Every version of the 1.0.9.x firmware that I've tried so far, inluding 1.0.9.6, 1.0.9.10, 1.0.9.26, 1.0.9.34, 1.0.9.64 (latest) continually reboots upon startup; presumably from a software crash. Not sure what is going on. I guess this wny so many people said "don't upgrade your firmware".
  • Just installed 1.0.8.34 and it came up all the way. Then rebooted after 15 seconds. Ugh. I'm enormously frustrated.
    • cabeaulac's avatar
      cabeaulac
      Downgraded firmware to 1.0.7.12_1.2.5 and it's been running for 5 minutes so far. It's a record. Letting it run now...
      Any clues why this is happening R7000 people?
        cabeaulac
        The router reboots when I connect a wifi device with firmware 1.0.7.12. Downgrading to 1.0.7.10. What version should I be using or is there some proceedure I'm missing?
