NCJeepMan
Sep 25, 2014Aspirant
R7000 5ghz Disappearing
Seems to be a lot of independent questions/discussions on or this topic or similar topics... Looking for someone to give me a definitive answer, so here's the question: - My R7000 periodically and ...
- Mar 26, 2016
I've been running Firmware Version V1.0.6.28_1.1.83 for a few months now without any 5GHz dropping. The big tip that helped me, was after doing the firmware update, I did a factory reset to reset all of the settings to default, and it also forces the router to get new internal drivers for itself. Before I did this, I was always losing my 5GHz.
JamesGL
Dec 04, 2015NETGEAR Employee Retired
Hi tstaal,
Have you performed a factory reset after the update? After the reset, manually reconfigure the router instead of loading the back up config.
tstaal
Dec 07, 2015Aspirant
Been there done that. REALLY disapointed with NetGear support. Simply request an RMA and I get this:
Sure feels like to bad so sad, If you want us to actually help you get the defective equipment fixed pay us...
- JamesGLDec 08, 2015NETGEAR Employee Retired
Hi tstaal,
I would suggest you contact voice support instead of the email support.
