NCJeepMan
Sep 25, 2014Aspirant
R7000 5ghz Disappearing
Seems to be a lot of independent questions/discussions on or this topic or similar topics... Looking for someone to give me a definitive answer, so here's the question: - My R7000 periodically and ...
- Mar 26, 2016
I've been running Firmware Version V1.0.6.28_1.1.83 for a few months now without any 5GHz dropping. The big tip that helped me, was after doing the firmware update, I did a factory reset to reset all of the settings to default, and it also forces the router to get new internal drivers for itself. Before I did this, I was always losing my 5GHz.
Sanjii
Jan 12, 2016Aspirant
I have the same issue, firmware version V1.0.6.28_1.1.83
All the settings are on:
| Wireless Settings (5GHz) |
But on the topleft of the box (left of Wireless Settings (5GHz)) there's an X instead of a V (like next to the 2.4GHz settings)
Where:
X = red circle with white X inside
V = green square with a check mark inside
- JamesGLJan 18, 2016NETGEAR Employee Retired
Hi Sanji,
Can you provide the screenshot so that we can have better understanding of your concern.
- MarsianManMar 19, 2016Aspirant
JamesGL wrote:Hi Sanji,
I am not Sanji, but I have the exact same problem. Firmware: V1.0.6.28_1.1.83
- JamesGLMar 23, 2016NETGEAR Employee Retired
Hi MarsianMan,
Have you reset the router to factory default after the update? Please be informed that the firmware has been pulled out from support site due to some issues reported. If still same problem after the reset, you may revert to firmware version v1.0.4.30.
