NCJeepMan
Sep 25, 2014Aspirant
R7000 5ghz Disappearing
Seems to be a lot of independent questions/discussions on or this topic or similar topics... Looking for someone to give me a definitive answer, so here's the question: - My R7000 periodically and ...
- Mar 26, 2016
I've been running Firmware Version V1.0.6.28_1.1.83 for a few months now without any 5GHz dropping. The big tip that helped me, was after doing the firmware update, I did a factory reset to reset all of the settings to default, and it also forces the router to get new internal drivers for itself. Before I did this, I was always losing my 5GHz.
pnmeldrum
Aug 22, 2015Aspirant
I too am experiencing this problem. It is very, very frustrating and disappointing, especially given the price of this router.
At this stage, given this ongoing and obviously common problem, I could not recommend this router to anyone, even though I want to.
Can someone at netgear please fix this issue asap. It has been an issue for too long.
I am using the latest firmware, V1.0.4.30_1.1.67
- clvnngSep 04, 2015Aspirant
I experimented with different channels on 5ghz and the only way i got it to stabilize is switching from 1300mbps to 600mbps. Then i can use any channel I want. The other solution was lowering the 5ghz channel to 40 which resulted in poor range.
I've had the router for less than 24hrs and the next step would be going to DD-WRT. but so far so good! I came from the legendary 54G so this is awesome =)
- netwrksSep 04, 2015Master
clvnng wrote:I experimented with different channels on 5ghz and the only way i got it to stabilize is switching from 1300mbps to 600mbps. Then i can use any channel I want. The other solution was lowering the 5ghz channel to 40 which resulted in poor range.
If you are looking for 3rd party fw, all the EX DD-WRT user's are using this firmware - I use on 2 R7000's. One as an AP and one in router mode, in different locations. Works great. Very stable, and lots of features that you won't find in stock FW. The instruction on the first page od the web site, are perfect for transitioning.
