Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
AlexAmparan
Mar 09, 2016Aspirant
JamesGL
Mar 13, 2016NETGEAR Employee Retired
Hi AlexAmparan,
You mean how to connect the PS4 to 5Ghz connection? If yes and if it supports 5Ghz, you may the network connection and look for the 5Ghz network.
