Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
Falconfe73
Feb 06, 2014Aspirant
JAMESMTL wrote: When you say static do you mean a dhcp address reservation on the router with the ps4 setup as a dhcp client or do you mean that you setup the ps4 with a static address in the LAN section of the ps4?
When you do a test internet connection on the ps4 what nay type is reported? And are all the tests successful?
Are you disconnecting completely from psn or just in game? Does this happen to all games?
Yes i reserved an ip address for the ps4. When i test the connection i obtain nat type 2 and all tests are succesfull.
When i'm in game i'm first disconnetct from the chat and after that from the game. i tried different game and the ruslts is the same.
I also teied to re install the firmware and i performed a complete reset of the router, but i don't solve the problem.
For example in cod ghost sometimes i obtain open nat, sometimes moderate... I'm thinking to return the router...
