Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
JAMESMTL
Feb 07, 2014Novice
Well I'm at a loss. Like I mentioned above it was pretty much plug and play for me.
The only things I can think of would be to open a support ticket with Netgear or to give dd-wrt a try before returning the unit. If you get a working solution I would be interested in knowing what worked.
Not being able to use my ps4 would be a deal breaker for me.
Good Luck
Good Luck
