Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
Lexist2112
Feb 07, 2014Luminary
Falconfe73 wrote: Yes i reserved an ip address for the ps4. When i test the connection i obtain nat type 2 and all tests are succesfull.
When i'm in game i'm first disconnetct from the chat and after that from the game. i tried different game and the ruslts is the same.
I also teied to re install the firmware and i performed a complete reset of the router, but i don't solve the problem.
For example in cod ghost sometimes i obtain open nat, sometimes moderate... I'm thinking to return the router...
Please try this. Sounds like you have done everything to configure the router correctly. The possibility exists that the PS4 may have some of the old config to your previous router.
Although I do not own a PS4, is there a way to:
1) Reset the wireless & LAN to default (clear any system memory)
2) reconfigure your PS4
3) power down the R7000 and reconnect power.
Let us know
