Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
Falconfe73
Feb 07, 2014Aspirant
In advance -- security -- schedule, i can only setup the time zone not the time or time server..
In the meantime i disable sip alg in the nat and reset and ps4 net connection and now it seems that ps4 is working.. I'll let you know after a deeper test!
