Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi, I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network. I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success....
- Feb 10, 2014After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
Temporel
Feb 07, 2014Novice
Falconfe73 wrote: The problem is that the time and date are wrong... At the moment the router date is 03.01.2003..
I see.
At first I thought it was strange that there was no time settings but the router is always spot on so Im fine with it.
Another "not universal" bug to add to the long list :(
