iochoa2
Dec 01, 2015Aspirant
R7000 Can not download firmware 1.0.5.48
I tried to download the firmware from the support site, but I got a trunkate file, with just 3 MB size, I could download the previous firmware, but the in the new release I got this problem, anyone that could help me.
Thanks.
Thanks, It was magic, I tried that several times, this time works!!
Thanks.
- Babylon5NETGEAR Employee Retired
Following the ‘Download’ link at the top of this page I was able to download the firmware you refer to, have you tried using a different computer / smartphone etc.?
- iochoa2Aspirant
Thanks.
- DanT2590Tutor
I've tried for a week and can't get 1.0.5.48_1.1.79 to download.
I also tried downloading the zip file, but when I went to unzip, it says not a valid format.
I would really like to upgrade since my version is getting pretty old since I flashed the memory.
What else can I try????
Have you tried downloading using other PCs?
I'm actually having trouble accessing the 'Downloads' page right now, I'm at work but even so can normally access it here, so I'm guessing that there may be server-side issues. If this is still the case at the end of today I will contact Netgear (or another moderator might check in the mean-time).
