ooeemusic's avatar
ooeemusic
R7000 can't access setting after setting up VPN
I set up thr R7000 last night because I recently started using express VPN. I followed the directions to set up the router and then the directions to set the VPN up. I now only have access to some of the routers setting through the express VPN router dashboard. I assume this is because it has changed the routers address, but I can't use the nighthawk app because of it and I can't get netgear genie to login even with the new IP address. Did I do something wrong in the set up? Or is this just how it works with a VPN that has it's own dashboard?
  • > [...] I followed the directions [...]
       _Which_ "the directions"?
    > [...] I recently started using express VPN. [...]
       If you installed ExpressVPN firmware on your R7000, then I would not
    be amazed if some features which are specific to Netgear firmware no
    longer work as before.
    > [...] Or is this just how it works with a VPN that has it's own
    > dashboard? [...]
       That would be another way to phrase it.  ("its", by the way.)
    • ooeemusic's avatar
      ooeemusic
      Directions = the directions the app gives you to set up the router and the directions express VPN gives you to set up the VPN on the router.
      • antinode's avatar
        antinode
        Guru
           "the app"?  But, in any case, if you install non-Netgear firmware on
        your Netgear router, then many things might change.
        > [...] the directions express VPN gives you to set up the VPN on the
        > router.
           Thanks for the helpful link.  But, in any case, if you have problems
        when using third-party firmware, then you might best ask the third
        party about them.
