Sanman99
Apr 24, 2023Aspirant
R7000 can't find SSID to connect
I've tried resetting the router multiple times. I've clicked the wifi button. I don't have access to a computer with ethernet right now.
- KitsapMaster
Sanman99 wrote:
I've tried resetting the router multiple times. I've clicked the wifi button. I don't have access to a computer with ethernet right now.Not sure what you are saying when you "clicked the Wi-Fi button"?
Check the LEDs across the top of the router. The second one in from the right side is a combination indicator/switch. Press and hold for a couple of seconds and the Wi-Fi should come on after you release.
- Sanman99Aspirant
That's what I meant. I pressed that button for two seconds.
The 2.4GHz and 5GHz indicator lights are on.
I've reset the router doing a 30-seconds holding the reset button while powered on, 30 seconds continued holding while off, and 30 seconds while plugging the power back in.
And I also did a simple 7 second reset. It's gone through rebooting.
