Gupster
Dec 23, 2016Aspirant
R7000 connectivity with HP wired laser jet
I've been using a HP Laserjet M553 for a few months connected via lan cable to the R7000 and it's been fine. But recently (last few weeks or so) it's lost connectivity. First time I was able to get i...
- Jan 05, 2017
I think i've found the issue, it looks like the cable was faulty as I've changed it and it appears to work with a new cable.
JamesGL
Dec 28, 2016NETGEAR Employee Retired
Hi Gupster,
1. Update the firmware of the router
2. Reset the router after the update.
3. Manually reconfigure the router.
