Gupster
Dec 23, 2016Aspirant
R7000 connectivity with HP wired laser jet
I've been using a HP Laserjet M553 for a few months connected via lan cable to the R7000 and it's been fine. But recently (last few weeks or so) it's lost connectivity. First time I was able to get i...
- Jan 05, 2017
I think i've found the issue, it looks like the cable was faulty as I've changed it and it appears to work with a new cable.
JamesGL
Dec 29, 2016NETGEAR Employee Retired
Hi Gupster,,
Yes, try the reset and manually reconfigure the device.
Gupster
Dec 31, 2016Aspirant
I'll give it a go and report back. Seems a little extreme to fix a hard wired lan device to work with the router.
- GupsterJan 01, 2017Aspirant
still nothing. resetup from new and the printer while initially lighing the lan port still hasnt got an IP and now the light only comes on and off. I guess it's something to do with it's power saving mode. I wonder if something changed in a recent firmware update.
