Gupster
Dec 23, 2016Aspirant
R7000 connectivity with HP wired laser jet
I've been using a HP Laserjet M553 for a few months connected via lan cable to the R7000 and it's been fine. But recently (last few weeks or so) it's lost connectivity. First time I was able to get i...
- Jan 05, 2017
I think i've found the issue, it looks like the cable was faulty as I've changed it and it appears to work with a new cable.
TheEther
Jan 01, 2017Guru
Does this problem occur if you connect a computer or laptop to one of R7000's LAN ports?
Check the logs on the R7000 and, if available, HP for any clues.
Gupster
Jan 05, 2017Aspirant
