harrma's avatar
harrma
R7000 default gateway missing
Whenever I try to use this router I get ip adress incorectly cinfigerd and when I do ip config /all the defalt gateway is missing and factory reset didn't work nor did these:
https://validedge.com/ethernet-doesnt-have-valid-ip-configuration/
https://www.techjunkie.com/ethernet-doesnt-t-have-a-valid-ip-configuration/
https://forums.tomshardware.com/threads/ethernet-doesnt-have-a-valid-ip-configuration.1979328/
The prevous owner said it stopped working when he updated the firmware, but I can't figure out how to fix it and I cant axsess the router page at its IP adress. Please help, thank you. (on windows 10)
