btwixt's avatar
btwixt
Guide
Dec 23, 2015
R7000: Device Name / Access Control
I'm not sure if this is a bug or a feature. Mind you, this is exactly the bug/feature I was searching for in the R7000.   I've a R7000 at F/W 1.0.5.48_1.1.79.   The inability to assign device na...
  • mondenath's avatar
    mondenath
    Dec 25, 2015
    Yes you are right ARP doest get the host/device name but tool allows to have a handy name the we can used to remember. It doesnt change the way we connect or any functionality. As the details are stored in accordance with MAC filter. So as IP Reservation. ACL have it own DB but IP Reservation sometimes doesnt cache even the QOS by device doesnt cache the same name instead the actual ANDROID_abcd etc
    ACL tool just adds tagging kind of which used to be refered even after reboot i dont think so if it flushs so that every time user needs to add .
