btwixt
Dec 24, 2015Guide
R7000: Device Name / Access Control
I'm not sure if this is a bug or a feature. Mind you, this is exactly the bug/feature I was searching for in the R7000. I've a R7000 at F/W 1.0.5.48_1.1.79. The inability to assign device na...
- Dec 26, 2015
Yes you are right ARP doest get the host/device name but tool allows to have a handy name the we can used to remember. It doesnt change the way we connect or any functionality. As the details are stored in accordance with MAC filter. So as IP Reservation. ACL have it own DB but IP Reservation sometimes doesnt cache even the QOS by device doesnt cache the same name instead the actual ANDROID_abcd etc
ACL tool just adds tagging kind of which used to be refered even after reboot i dont think so if it flushs so that every time user needs to add .
mondenath
Dec 26, 2015Prodigy
btwixt
Dec 26, 2015Guide
mondenath,
Re: "ACL tool just adds tagging kind of which used to be refered even after reboot i dont think so if it flushs so that every time user needs to add ."
Yes. That is exactly what I am observing. The tagging works for me... as long as i keep in mind that it may not be the actual device name.
I mean... if the tagging hasn't changed in two months, after at least 3 power cycles & 36 reboots (for an unrelated issue),
I guess it will be persistent until I edit it differently.
And a sincere "Thank You!" for helping me understand.
- btwixtJan 14, 2016Guide
I guess we're done here.
R7000 @ V1.0.5.48_1.1.79 is working fine for me,
device names & all.
