ringlord
Nov 28, 2016Apprentice
R7000 DHCP offer but no connection can be made on 5Ghz band
 R7000 Windows10 / Android   Firmware = 1.0.7.2  Modem = 192.168.0.1  Router = 192.168.1.1  (R7000)  Hi I had a horrible weekend getting my R7000 to work again after replacing the modem from the ISP. ...
- Nov 30, 2016Welcome to the community, ringlord Sounds like a faulty router. Can you try the following reset below then reconfigure the router. 1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds. 2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds. 3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go. Try to reconnect your devices on 5GHz and see if it will work.
ringlord
PS This is what we can see in the log :
[DHCP IP: (192.168.1.2)] to MAC address CC:FA:00:B4:EE:48, Monday, Nov 28,2016 19:41:12
[DHCP IP: (192.168.1.2)] to MAC address CC:FA:00:B4:EE:48, Monday, Nov 28,2016 19:41:02
[DHCP IP: (192.168.1.2)] to MAC address CC:FA:00:B4:EE:48, Monday, Nov 28,2016 19:40:52
[DHCP IP: (192.168.1.2)] to MAC address CC:FA:00:B4:EE:48, Monday, Nov 28,2016 19:40:42
ElaineM
Nov 30, 2016NETGEAR Employee Retired
- ringlordNov 30, 2016ApprenticeThanks ElaineM it has been a rough ride with this router. Your reset procedure seems to have helped quite a bit since I now can connect on the 5Ghz band but I am not yet completely convinced that the connection is stable since I sometimes still get network connection errors for example on my Nexus 5. Also the speed of 50/6 on the 5Ghz channel is less then I used to get. I append the new logfile here so you can see that still multiple DHCP offers were needed but eventually the connection succeeded. The odd thing about this reset procedure is that my settings were retained. (I tried it twice with the same result) [DHCP IP: (192.168.1.10)] to MAC address CC:FA:00:B4:EE:48, Wednesday, Nov 30,2016 21:59:56 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:59:17 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:59:07 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:57 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:47 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:37 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:21 [DHCP IP: (192.168.1.8)] to MAC address B8:E9:37:EE:77:72, Wednesday, Nov 30,2016 21:58:21 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:18 [DHCP IP: (192.168.1.8)] to MAC address B8:E9:37:EE:77:72, Wednesday, Nov 30,2016 21:58:18 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:16 [DHCP IP: (192.168.1.9)] to MAC address B8:E9:37:EE:76:FC, Wednesday, Nov 30,2016 21:58:16 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:15 [DHCP IP: (192.168.1.8)] to MAC address B8:E9:37:EE:77:72, Wednesday, Nov 30,2016 21:58:15 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:13 [DHCP IP: (192.168.1.9)] to MAC address B8:E9:37:EE:76:FC, Wednesday, Nov 30,2016 21:58:13 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:12 [DHCP IP: (192.168.1.8)] to MAC address B8:E9:37:EE:77:72, Wednesday, Nov 30,2016 21:58:12 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:58:07 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:57 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:47 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:37 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:27 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:17 [Time synchronized with NTP server] Wednesday, Nov 30,2016 21:57:16 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:14 [DHCP IP: (192.168.1.7)] to MAC address A4:77:33:3E:7C:C0, Wednesday, Nov 30,2016 21:57:13 [DHCP IP: (192.168.1.6)] to MAC address 1C:6F:65:C8:C5:F4, Wednesday, Nov 30,2016 21:57:13 [DHCP IP: (192.168.1.5)] to MAC address 20:78:F0:31:08:F8, Wednesday, Nov 30,2016 21:57:13 [DHCP IP: (192.168.1.3)] to MAC address 24:DA:9B:01:55:2E, Wednesday, Nov 30,2016 21:57:12 [Internet connected] IP address: 91.177.37.230, Wednesday, Nov 30,2016 21:57:11 [DHCP IP: (192.168.1.2)] to MAC address D8:50:E6:90:92:4E, Wednesday, Nov 30,2016 21:57:08 [DHCP IP: (192.168.1.4)] to MAC address 8C:C1:21:5B:60:75, Wednesday, Nov 30,2016 21:57:04 [Initialized, firmware version: V1.0.7.2] Wednesday, Nov 30,2016 21:57:02 - ElaineMDec 01, 2016NETGEAR Employee RetiredIf it keeps disconnecting, try to check for other channels. You may also want to try to adjust the Fragmentation Length and CTS/RTS Threshold to 2304. Then reconnect to the network.
