lolcocks's avatar
lolcocks
R7000 dropping all static route packets
Hello,
I have two routers in my network connected to one another. When I set a static route from my first router (R6400 with DD-WRT) to the second one (R7000 with stock OS), the second router (R7000) drop all the packets coming from the static route.
Heck, I have even disabled SIP ALG on the R7000, yet it won't allow the static route packets to get through.
How can I change this? Is there any settings I missed on the R7000 router? I don't want to flash DD-WRT on the R7000 because DD-WRT network signal on the R7000 does not reach as far as the stock OS.
My setup looks like this:
ISP Modem -> R6400 (10.0.0.1) -> (10.0.0.3) R7000 (192.168.1.1)
Requesting help.
    I fixed the issue by flashing Xwrt-vortex, a custom firmware that supports NAT from other subnets.
    In the end, the culprit was the NETGEAR firmware. There were no issues in routing.
    antinode
    Really disappointed in NETGEAR firmware and it's support.
    I won't be buying NETGEAR as my next router.
    • lolcocks's avatar
      lolcocks
      Apologies for being such a mess.
      Here are screenshots of all my settings and what happens when I ping them:
      Same results when I ping them from PC instead of router.
      https://imgur.com/a/xz1FqHZ
      • antinode's avatar
        antinode
        Guru
        > [...] Or what your "my ISP's modem" might be.
           Still wondering.  Is it a modem or a modem+router?  If the latter,
        then what are its IP addresses (LAN and WAN/Internet)?
           If your "my ISP's modem" is a simple modem, then I would expect the
        LAN subnet of the (DD-WRT) router which is connected to it to be
        "192.168.1.*", not "10.0.0.*".
           In the first picture, I'm not sure what the circles and arrows are
        supposed to tell me.
           The second picture seems to show a reasonable route for the
        "192.168.1.*" subnet.
           In the third picture, I'd expect a WAN subnet mask of
        "255.255.255.0", rather than the default for a "10.x.y.z" subnet
        ("255.0.0.0").  But that may be mostly harmless.
           The fourth picture seems to show "Respond to Ping on Internet Port"
        being checked.
           The fifth picture seems to show a working "ping", from the DD-WRT
        router to the R7000 WAN/Internet port, which I'd expect.
           The sixth picture shows a failing "ping" from the DD-WRT router to
        the R7000 LAN interface.  I'm not sure if I'd expect that to work or
        not.  What happens if you connect some device to the R7000 LAN, and
        "ping" it (from the DD-WRT router)?
           My fear (based on the unexpected DD-WRT router subnet) is that your
        "my ISP's modem" is a modem+router, and that its LAN is using the
        "192.168.1.*" subnet.  In that case, the DD-WRT router might think that
        a message for "192.168.1.X" should go to its own WAN port, and. thus,
        not to follow the (lower-priority) route which you added.
        > If you would need anything more, please let me know.
        > [...] WAN/Internet IP address of each router? [...]
           In particular, that of the DD-WRT router (if it's not your public
        address).
  • > Still wondering.  Is it a modem or a modem+router?  If the latter,
    Not sure, I think it is a modem:
    http://www.castlenet.com.tw/page/49
    I have tried multiple times before, there doesn't seem to be any way to login or access the web GUI of that modem, maybe it doesn't have one? It doesn't even show up on trace routes.
    10.0.0.1 is my first router (R6400 DD-WRT).
    10.0.0.3 is the static IP of the second router (R7000) to connect to the R6400.
    192.168.1.1 is the local IP of second router (R7000) and clients connecting to it will get 192.168.2-254 IPs.
    I tried both "255.255.255.0" and "255.0.0.0", didn't work on either.
    I have a wired device (Windows machine) connected to the R7000 with firewall turned off on it. It too drops all the packets.
    Actually the trace route stops at 10.0.0.3, so I am not able to enter into the 192.168.1.1 network of R7000. Which means the R7000 itself is dropping all the packets.
    The IP address of the R6400 is 10.0.0.1, it's DHCP clients gets IP from 10.0.0.100 to 150.
    The IP address of the R7000 is 10.0.0.3 to connect the the R6400. It's DHCP clients get the IP 192.168.1.100 to 150.
    I don't know the ISP's modem's IP, it doesn't even show up on trace routes.
    I am a newbie but not sure how the ISP's modem comes into picture here since I am trying to connect R6400 to the R7000.
    antinode
    • microchip8's avatar
      microchip8
      Master
      You're violating both license and copyrights by installing XWRT, which is an illegal fork of RMerlin. Better load FreshTomato instead
      • lolcocks's avatar
        lolcocks
        I wish I could microchip8 .The Xwrt-Vortex is the only one which supports hardware accelatration.
        The other firmwares do not support hardware accelaration and drops down my WiFi signal strength by 30%. And I need the extra signal strength to cover all rooms.
        I know, the Xwrt-Vortex is not even open source, nobody knows what he might be running. There might even be backdoors.
        But I don't have a choice. Either I lose WiFi signal in two rooms or I lose the ability to NAT other subnets if I use NETGEAR firmware.
        I feel like I was thrown under the bus here by NETGEAR.
