xrender
Apr 04, 2017Tutor
R7000 Dynamic QoS Throttles LAN transmission
I am surprised and happy to see that the new firmware adds supports Dynamic QoS on R7000. However, it seems that the Dynamic QoS will throttle the local transmission in the LAN network. I have a Samba sharing device in the LAN and found that the upload from my desktop is throttled around the QoS upload bandwidth, which should not happen since it is not WAN traffic. The LAN download does not have this issue though.
When enabling dynamic QoS, my LAN upload is throttled around 500KB. After disabling the QoS, the LAN upload is around 15MB. The old upstream QoS does not have this issue
The problem is solved after setting my LAN HOME_NET back to 192.168.1.xx (255.255.255.0). Not sure if this is actually a bug or it is my configuration that is improper.
- mondenathProdigy
Which version are you referring to. Can you post the setting screenshot of QOS.
Do give some layout of the actual devices connected and mode of transfer. there might be many factors that could affect this .
- xrenderTutor
The firmware version is 1.0.7.12_1.2.5
Some additional observation: the upload speed is not throttled exactly at 4.7Mbps. The peak speed could be around 10Mbps but is still far below the speed without QoS (15~20MB/s)
I simply transfer the large file using ordinary Windows 10 file sharing protocol (both my client computer and file server run Win10). Both the server and the client are at 10.0.0.xx in the LAN
Can you connect a external Gb network switch between the PC and the Server and test? Connect one port of the switch to the router.
