AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
Retired_Member
Jan 14, 2016I'm having the same issue so I downgraded to previous firmware and everything is fine....Should I do a factory reset and try new firmware? There seems to be a issue with mobile devices connecting to the newest firmware release.
LeeH
Jan 15, 2016Prodigy
"I'm having the same issue so I downgraded to previous firmware and everything is fine....Should I do a factory reset and try new firmware? There seems to be a issue with mobile devices connecting to the newest firmware release. "
I wouldn't upgrade if you are happy with your routers performance. Any time you change firmware you should reset, flash and reset again. Each reset with the reset button on the back pressed for at least 10 seconds until the lights flash. Also make sure you enter your configuration by hand and not from a backup file.
