AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
LeeH
Jan 15, 2016Prodigy
"I'm having the same issue so I downgraded to previous firmware and everything is fine....Should I do a factory reset and try new firmware? There seems to be a issue with mobile devices connecting to the newest firmware release. "
I wouldn't upgrade if you are happy with your routers performance. Any time you change firmware you should reset, flash and reset again. Each reset with the reset button on the back pressed for at least 10 seconds until the lights flash. Also make sure you enter your configuration by hand and not from a backup file.
LeKeiser
Jan 17, 2016Luminary
The fact that you have to reenter all the time all the settings suxx big time, I wonder what's the point of having a backup then. This is also something that Netgear should work on.
You're going to say that the backups are good if you don't change the firmware. But then, what's the point of having to load the backups if you're not changing anything?
- JamesGLJan 17, 2016NETGEAR Employee Retired
Hi All,
Please refer to the thread below for this issue.
- Retired_MemberJan 17, 2016
1.0.6.28 FIRMWARE IS HOSED !!!!!
Until today I truly hadn't had any issues with it. A few minutes ago I decided to turn off 2.4 and see how my network would handle it. I was shocked to see the Arlo SSID (netgear02-arlo_246656) pop up when checking INSSIDER. Make NO MISTAKE is was not there and hadn't been since disabling it last Sunday.
So I checked router setup and Arlo WAS STILL DISABLED. SO how the blank did it turn it self on? I'm seriously TIRED of wasting time doing YOUR job. TEST YOUR GD FIRMWARE.
