bbbf0621
Mar 29, 2016Guide
R7000 internet speed drops after firmware update
I've been using R7000 with my 1Gbps internet service and able to reach up to 980Mbps+ until i upgraded my firmware to 1.0.6.28_1.1.83. Since then the speed reduced to around 550Mbps up and 800Mbps down. As you might aware enabling the traffic monitor of this machine will cap your bandwidth to 500Mbps for all firmware but it is not enabled in this case.
I thought it was my settings so i made a factory reset but it didnt help too. Is anybody else having the same issue? Are there any solutions to this? Which firmware would you suggest for my situation provided that i want to use the open VPN package for smartphone. Thank you so much.
The firmware you are running was pulled by Netgear a few weeks back, as there were a multitude of issues.. Go to NG site and download the most current on site - 1.0.4.30. When you have downgraded the firmware reset your router to factory default and reconfig router from scratch.
- netwrksMaster
- bbbf0621Guide
Im down to 1.0.40 already. up speed is fine but the down speed still around 500Mbps, any ideas?
- netwrksMaster
Have you tested directly connected to your ISP modem, to see if you are getting you intended Internet speed?
Did you reset the R7000 to factory default after the downgrade? If you haven't, that would be a good starting point.
