leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
leong163
Dec 09, 2014Novice
All my computer equipments are surge protected. I have replaced the surge protected power bar twice already. I think the power supply issue is slim in my case. During the time of losing connectivity, all lights on the router look normal. Usually, after a minutes or so, it reconnects. The losing connectivity problem is happening randomly any time of the day. Any suggestion?
