leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
leong163
Dec 12, 2014Novice
The telco ADSL modem has been set up in "bridge mode" during the installation of R7000.
The telco router uses IP "192.168.1.1" and my R7000 uses "10.0.0.1" and the DHCP is done by R7000. I believe this IP setup arrangement should not cause problem, right?
