leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
Mars Mug
Dec 13, 2014Virtuoso
If your Bridged modem is allocating Private IP addresses rather than the Public IP address then it’s most likely not correctly set to Bridged Mode.
In the R7000 status page what do you see for the IP address of the Internet Port, just post the first two numbers, not the full IP address?
