leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
bill1228
Dec 13, 2014Guide
leong163 wrote: I am not aware R7000 will support DD-WRT. I will consider this as last solution when no other easy way out.
Thank you very much.
Yes DD-WRT does support the R7000. Am running it on my R7000. There are issues with DD-WRT on the R7000, biggest is reboots if using "new driver" builds. Builds with the old driver, such as Kong 24345OLDD do not have the reboot issue. This is the build I run.
--bill
