leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
slidermike
Dec 13, 2014Aspirant
just to be clear.
Bill is mostly right.
SOME r7000 are having a random reboot issue on the newer firmware but not all.
The only way to know is to try it. If you don't like it, flash one of the older with the oldd in the name or back to stock.
