leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
RogerSC
Dec 14, 2014Virtuoso
msabadish wrote:
Will be returning the R7000 unless the good folks at Netgear deem this one to be a lemon and send another my way.
Mike
Sounds like you should be able to get an RMA out of them. As long as you're following best practices (resetting to factory defaults after flashing firmware, and then manually entering your settings), you shouldn't be seeing spotaneous reboots with the stock firmware.
