leong163
Dec 08, 2014Novice
R7000 keep losing connectivity
Firmware version V1.0.3.80_1.1.38 Everyday, the router is dropping connection to all my devices (e.g. computer, NAS, TV, mobile, etc.) regardless it is wired or wireless connection. Someday, it ke...
- Dec 15, 2014Netgear support has sent me a beta firmware to test. It has been running for over 24 hours without connectivity problem. Initially, it was not working until I first did hardware factory reset. Directly applying the beta firmware did not work.
Thank you for all the people who have been given me the support and help. You are the best.
stenopete
Dec 15, 2014Tutor
msabadish,
WOW. I can see and 'feel' your frustration. I recall when I had my wndr3700 and boy was it 'screwey' and lets not touch on the firmware issues on that.
With that said - R700 is a terrific router - I own it and speak from experience. On both sides of the firmware, DDWRT and NETGEAR FW.
From what you wrote it sounds like bad fw.
Check your PM. :)
