szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
JamesGL
Oct 23, 2015NETGEAR Employee Retired
Hi All,
Have you tried to use the beta firmware for this router? You can check this link.
JamesGL
Community Team
MikeyPf
Jan 18, 2016Aspirant
I also have the problem with not being able to delete files from an attachd usb drive from a windows computer without changing the properties from read only. Unfortunately eventually the properties change back to read only, usually pretty quickly but not to quickly to be able to delete the files or folder. But weirdly, using when using esfile explorer from an adroid tablet or smartphone I have no problem deleting items from the drive. I wonder if there's a file explorer app for windows 10 that might work? Will look for some and if I find any that work will post.
