szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
szewski
Jan 26, 2014Guide
ok - so not having much success with Netgear support. They had me try an older firmware. While I appreciate the suggestion, as they are willing to see if it is something in their code, if the problem existed in the older firmware, it wouldn't reveal it. In this case, it did not resolve the problem. They then asked if I had the issue with 2nd USB drive. I borrowed one and tried it for a week and eventually the problem occurred on the 2nd drive as well.
Would be nice if the could build in a file management utility into the UI which would be directly UNIX and not Windows to UNIX. or at the lease a reset all files/folders permissions.
Anyone else seeing this?
