szewski
Jan 09, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
DanPaganelli
Jan 29, 2014Novice
Yes - this problem is infuriating.
The only fix I have found is to plug the USB device into my computer and have windows repair it, which takes forever.
I am really hoping for a fix soon as I am not a fan of losing large amounts of data or not being able to write to/delete anything from the USB device.
NETGEAR are you listening?? :confused:
