szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
rprichard
Feb 15, 2014Aspirant
If you can, look at case# 22705879 that I filed on data corruptions issues I'm having with both a USB3 and USB2 HD drives..If I move the drives back to my iMac, it reports they need to be verified and eventually repaired,,During repair It then tells me it can't repair and I need to back up the files and reformat the drive... The Drives work fine when connected and shared directly from the iMac or other computers.
It certainly looks like there is a problem with their device drivers, and/or, drive management.. Very frustrating..I can't keep copying 500G of files back and forth all the time!
I also have a recent post on the R7000 forums regarding Extended Journaled and GUID partition problems that outline all the problems and testing that I have done.
