szewski
Jan 09, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
CDLNet
Feb 23, 2014Initiate
Hi Guy,
I am new to the forum today, but have good experience re: WNDR3800 and R7000 USB HDD file access issues, etc.
Bottom line:
files and folder do seem to get 'locked out' somehow... not sure why...
if you get an error when trying to access the shared folder or file, something like, "Unix/Nobody..."
To correct, simply find the folder on the HDD (not need to disconnect from the router),
right click, properties
clear the read only box
worked for me on several files
Good luck.
CDL
Bottom line:
Good luck.
CDL
